LabWindows/CVI
GetFirstFile and GetNextFile while looking for folders
In LabWindows 7.0 "C" I am using a wild card construct to search for folders in a folder called "PAT_DISKS" as shown below:
 strcpy(work,"c:\\DEVELOPMENT\\PAT_DISKS\\????MS??_DSK_PAT");
 is = GetFirstFile (work, 0, 0, 0, 0, 0, 1, name);
 is=GetNextFile (name);
there are at least three folders matching the criteria in "PAT_DISKS" but "GetNextFile" does not find them.
Is this a bug in LabWindows CVI 7.0  ?
(4,421 Views)
Well, I do not have CVI 7.0, but I have 6.0.
I created the exact directory structure in my PC, did the same function call and it was successful for both GetFirstFile and GetNextFile.
Attached are the screenshots.
Did you try bu setting the normal attribute to 1?
S. Eren BALCI
IMESTEK
(4,409 Views)
Accepted by topic author sweeneyguidant
Thanks,  your response helped me to find the problem.   As normal, it was between the keyboard and the chair.  Without realizing it, I was pointing to an alternate folder I had established earlier for debugging purposes.  There was in fact only one subfolder there so the "GetNextFile" function was working properly.
Rob
(4,389 Views)
