LabWindows/CVI
GetTableCellVal:“the index passed is out of range”
I creat a Table Control,some code in the callbacks of Timer Control like this:
int a,b,i=1;
GetNumTableRows (panelHandle, PANEL_TABLE, &a);
if (i<=a)
  GetTableCellVal (panelHandle, PANEL_TABLE, MakePoint(1,i), &b);
else i=1;
ComWrt (1, b, 1)
When I debug the program, there was a mistake:
NON-FATAL RUN-TIME ERROR:   "7.c", line 346, col 21, thread id 0x000007F8:   Library function error (return value == -55 [0xffffffc9]). The index passed is out of range
How to solve this problem?
(3,474 Views)
Additional information:
befoe this Table Control,I have a Button.Its function is as follows:
InsertTableRows (panelHandle, PANEL_TABLE, -1, 1, VAL_CELL_NUMERIC);
(3,471 Views)
1) which function call reports this error?
2) the function ComWrt is defined as follows: int ComWrt (int portNumber, char buffer[], size_t count); so your second parameter should be a string, not an integer
(3,454 Views)
