LabWindows/CVI
Getting Windows SDK function returned an error. (Error code -12) while building the D-kit
 I use LabWindows CVI 8.5 to build the D-kit in windows xp os.when i try to build the D-kit it is throwing the following error.i have attached the error log along with this post.request to provide solution to over come this issue ASAP.it is very urgent.Thanks in advance
Regards
Parthipan
(4,234 Views)
I have not a direct experience on distribution kit, but the error seems related to the absence of NI-DMM 3.0.2 disk in your CD reader (D:): could it be the cause?
(4,226 Views)
no the disk inserted contain ni dmm.it is the disk got from ni.
(4,219 Views)
Are you still having issues with this? Is this the same disk that you used to install the DMM driver with? In the Drivers & Components tab of the Edit Installer dialog, slect Change Source for the DMM driver and make sure it is locating the setup.exe.
If that does not work, download and install the driver from ni.com/drivers and then use that as the component source.
(4,193 Views)
