LabWindows/CVI
Getting "Mesa.dll could not be found" error
I get this error after updating to latest Lab Windows/CVI runtime engine ver 7.0. Error show up upon opening Puritan Bennet Breathlab PTS test software. I'm running windows XP.
(4,499 Views)
mesa.dll is a module used for user interface components and should have been installed by the CVI run-time engine.
the dll should be at C:\Program Files\National Instruments\Shared\Mesa. Make sure that you have the dll in the system. I would suggest that you uninstall the run-time enigine, delete this folder and reinstall the run-time engine. Then you can check whether this component was intalled or not.
I hope this helps.
Juan Carlos
N.I.
(4,499 Views)
