LabWindows/CVI
Getting the CPU temperature
Okay, thanks!
I will look up which CPUs are supported somehow.
I would guess based on very little testing that the same CPUs as the NI System Monitor library.
Message 11 of 13
(1,458 Views)
The specific CPU is likely less important than the OS you run on. If you test under Windows you likely get different results than in Phar Lap ETS as to what is supported and again different if it was NI Linux RT. Linux would be pretty easy as you also just can read some /proc/.. entries with file IO normally.
Rolf Kalbermatter  My Blog
Message 12 of 13
(1,453 Views)
Yes, on linux this would be way easier, but unfortunately we can not upgrade the OS.
Message 13 of 13
(1,450 Views)
