LabWindows/CVI
Getting the state of the sequence execution from the operator's interface
I'm using the CVI operator's interface (simple) that comes with TestStand 3.1 and I need to know the state of the execution (running/terminated...).  How can I get a handle to the execution or is there some kind of an event posted by the TestStand engine that the application can recieve?
Thanks.
(3,075 Views)
as you are using the simple operator interface, you can use the ExecutionViewMgrGetExecution method ("Ni TestStand UI Controls 3.1" Instrument Driver under "ExecutionViewMgr") to get a handle to the current execution running. This handle you can use in the ExecutionGetSates method ("Ni TestStand API 3.1" Instrument Driver under "Advanced-->Execution") to get the state of the current execution running.
Hope this helps.
(3,052 Views)
Problem solved thanks to your solution.
(3,048 Views)
