LabWindows/CVI
Give a handmake function to search all files in the directory.
To scan drive, folder, ets.
I maked this, but my function is big bleep, a devil will break his legs here.
Need small workable solution.
(3,908 Views)
Sergey,
Here is an example file which looks through every file in a directory.http://zone.ni.com/devzone/cda/epd/p/id/2157
It should save you some time if you are having issues with your code.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(3,819 Views)
There is a filebrowser custom control (toolslib\custctrl\FileBrowser.fp) that has an example of how you can do this with GetFirstFile and GetNextFile functions from the Utility Library. In FileBrowser.c check out PopulateListFromPath.
You can drop a file browser custom control in the UI editor to play around with it by right-clicking a panel in the UI editor in edit mode, and selecting Custom Controls>>Toolslib Controls>>File Browser.
(3,748 Views)
