LabWindows/CVI
Give same name to writing file as reading file
I have a bunch of raw data files that needs to processed. I have construcetd a block diagram which read the file, process it and write it to a different location. Now I want the output file(i.e the write files) to hava the same name as input files. How do I automate this process?
(3,361 Views)
Your mentioning of the block diagram makes me think you are using LabVIEW for your application. If this is true, you should post this question to the proper forum.
Anyway, whichever is the programming environment, knowing which functions you are using to write the output files can help us in suggesting the best solution.
(3,349 Views)
