LabWindows/CVI
Global function
Hello everybody... i have an issue...
i have made many functions, which i will use them i another projects in C... i dont know how i should add them ad global functions... how should i add them for example in math.h or another header files... i appreciate your support... kind regards, venus
(2,398 Views)
Hello Venus,
What you could do is int the variable:
"int variable = 0;"
then in your other code call it again:
"extern  int variable;"
Similarly to how they did it on this post: https://forums.ni.com/t5/LabWindows-CVI/How-do-I-handle-global-variables-and-include-files-when-usin...
Best,
MrJacket
(2,289 Views)
