LabWindows/CVI
Got problem with dll usb/dmx
Hi all,
I use CVI 7.1 and Win XP.
Try to use USB/DMX Interface.
I have write a small program to controll some lights.
For this project i try to use a external DLL and LIB.
the header file looks:
#ifdef __cplusplus
extern "C" { /* Assume C declarations for C++ */
#endif
#define FUNCTION __declspec(dllimport)
FUNCTION __stdcall StartDevice();
FUNCTION __stdcall SetData(long Channel, long Data);
FUNCTION __stdcall SetChannelCount(long Count);
FUNCTION __stdcall StopDevice();
#ifdef __cplusplus
#endif
But everytime i get the same error message:
4 Project link errors
Undefined symbol '_SetChannelCount@4' referenced in "dmxtest1.c".
Undefined symbol '_StopDevice@0' referenced in "dmxtest1.c".
Undefined symbol '_StartDevice@0' referenced in "dmxtest1.c".
Undefined symbol '_SetData@8' referenced in "dmxtest1.c".
Can anybody help with this?
What can I do?
thanks
(4,531 Views)
Have you added the .lib (Import library) to your project?
(4,512 Views)
thanksy for your help,
but
yes I added the the .lib file and the .dll is in the \WINDOWS\system.
My function call looks:
int CVICALLBACK dmx (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
Channel = 1;
Data = 100;
Count = 8;
StartDevice;
SetData(Channel, Data);
SetChannelCount(Count);
break;
return 0;
I don't find the error.
where is it?
I get everytime the Undefined symbol '-StartDevice.....'
message error.
new ideas?
thanks
(4,510 Views)
Try "StartDevice();" instead of "StartDevice;".
Could you attach an example, so that I could try it out here?
(4,507 Views)
If I try "StartDevice();" instead of "StartDevice;".
I get the message error "missing prototype".
Here is my attached project.
(4,505 Views)
Something is wrong with your inport library. Good thing is, that you can create a new one from CVI:
Open the Header of the DLL (K8062D_DLL.h). Choose "Options->Generate DLL Import Library..." from the menue. Selct the DLL in the next dialog. After that, a  new .lib will be created. use that one instead of the original .lib, and your programm will work. I attached the lib I created.
André
(4,500 Views)
HiAndré,
thanks for your help.
The Software is running.
(4,450 Views)
