LabWindows/CVI
Graph and cursor
I need to obtain the coordinates of a point somewhere in a graph, when I
click on this point.
I try this using this function:
int CVICALLBACK Curve_Click (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_LEFT_CLICK:
GetGraphCursor (panelHandlePlot, PANEL_PLOT_GRAPH, 1, &x_cursor,
&y_cursor);
break;
return 0;
where x_cursor and y_cursor are defined globally.
However, the cursor does not jump to the place where I click. Also, I do not
obtain the coordinates of the place where I click, but the coordinates of
the place where I clicked previously.
A way to avoid this is adding an extra command button, which calls the
functions:
andlePlot, PANEL_PLOT_GRAPH, 1, &x_cursor, &y_cursor);
SetGraphCursor (panelHandlePlot, PANEL_PLOT_GRAPH, 1, x_cursor, y_cursor);
The user then has to click first somewhere in the graph, then click on the
command button. Only then the cursor jumps to the place where the user has
just clicked. This is quite confusing and non-intuitive for the user.
Is there a better way to do this?
Kind regards,
Geert Van Doorselaer
(3,667 Views)
Use EVENT_COMMIT instead of EVENT_LEFT_CLICK and your problems are gone !
EVENT_LEFT_CLICK is called before the actual movement of the cursor, hence
you get the old coordinates.
When EVENT_COMMIT is called, you can be sure that the user-action is
finished !
Manfred
Geert Van Doorselaer schrieb in im
Newsbeitrag: 3b82668e@newsgroups....
> switch (event)
> &y_cursor);
> break;
> return 0;
not
> functions:
&y_cursor);
> Kind regards,
(3,667 Views)
"Manfred Schininger" wrote in message
news:3b82b8f1@newsgroups....
> finished !
> Regards,
> Manfred
You are very right about this. Thanks for your help and time!
Kind regards,
Geert
(3,667 Views)
