LabWindows/CVI
Graph control manual axis limit change bug
I have a simple graph control in my program that displays an XY curve (using a linear xy scale, with x axis gain and offset set to specific (double) values) . The axes are set to Editable, which allows me to change the limits on X and Y axes in GUI. The changes work correctly, except when I change the X maximum value - it changes to the newly set value, but causes a simultaneous change in the X minimum value, setting it to a large negative number.
This only happens when I use X Gain setting that is less than 1.0.
The behavior when changing X minimum value is normal and doesn't affect the X maximum value.
It looks like a bug.
(2,825 Views)
Well, attach a VI containing default data in the graph so we get an idea what you are describing.
(2,779 Views)
This is LabWindows not Labview. What type of files are you looking for?
(2,758 Views)
Can you pare it down to a minimal example project? Or modify a sample project slightly that comes with CVI? Then some people here would be able to replicate it and help.
(2,720 Views)
Here is a simple example project I created.
After hitting the Plot button, a simple diagonal curve is drawn. Box X and Y axes limits can be manually changed. Only the change in X axis Maximum value creates a problem.
(2,707 Views)
Do you have any suggestions?
(2,660 Views)
