LabWindows/CVI
HIPAR TAG warning
What does this error mean? I create my c file from template. When I delete the template function code and define my own function, the warning information occurs when compile the code.
(4,884 Views)
You may have noted this HIFN, HIRET, HIPAR lines on the source code you started from: they are documentation tags, whose description and use can be found here. They are useful to generate source code documentation and can assist you in developing your application, as they appear in the help tooltip that you can show by pressing Ctrl + Shift + Space on a function name.
The error you are facing now simply means the you started from a function definition with some parameters, removed some of them but left the correspinding HIPAR tag: the system warns that a parameter tag is found which does not match any parameter defined in the function. It's a non-blocking warning.
(4,876 Views)
