LabWindows/CVI
HOw to set up the excel page layout in A4 format with Excel_SetProperty
I am handling excel sheet in my CVI code using the Excel_rpt api.
ExcelRpt_ApplicationNew(0, &applicationHandle);
ExcelRpt_WorkbookNew(applicationHandle, &workbookHandle);
ExcelRpt_WorksheetNew(workbookHandle, -1, &worksheetHandle);
I want to configure the page layout as A4.
I am using the Excel_SetProperty function, but it does not work,
Excel_SetProperty (workbookHandle, NULL, Excel_PageSetupPaperSize, CAVT_VARIANT,CA_VariantInt(ExcelConst_xlPaperA4))
Does any one has ever try to do such configurqtion?
Thank you
(546 Views)
I'm not an expert in CVI but I think that you are applying the Excel_SetProperty at the wrong location.
When using the Excel Report (ExcelRpt) API in LabWindows/CVI, setting the paper size should be done on the worksheet's PageSetup object, not on the workbook.
Tell me if it helps you or if you would require more help.
(488 Views)
