LabWindows/CVI
Harware Timer with PCIe-6363
I've been successfully using a 1ms Async Timer for years in my control software for several years, but the application seems to be on it's limits these days.
For improved stability, I would like to try using a hardware timer to generate the callback function instead of an software Async timer.
It seems that I cannot use the "Signal Event" with my PCIe-6363 card.
1) should I be able to do this with any of the functionality on my card?
2) If not, is there a cheap counter card/usb that I can add that will?
Terry Moss
Technical Manager
Robert Bosch
(1,874 Views)
PCIe 6363 has 4 counters/timers, Why you cannot use the Signal Event?
(1,822 Views)
As I tried it, I received an error message that said it wasn't supported.
(1,811 Views)
There are a few examples on the official web page have you tried them?
(1,778 Views)
