LabWindows/CVI
Help Plz!!!!!!!!!How to communicate with a USB port as we does with a COM port using RS 232 library
Hi All,
      In our project we use RS232 library to communiacte with COM Port.But my problem is:
     Now we are having Acer's laptops using WindowsXP with USB ports not COM ports.But we use an adapter and communicate with this USB port as with a COM Port.Each time when we return from standby mode the COM port that is assigned differs and hence program doesn't work since it always search for a specific port say COM2.Is there any mechanism to chk which COM port has been assigned to USB port.i.e., I must be able to know which COM Port has been assigned to USB port before data acquisition starts.Plz help.
Mala
(3,354 Views)
You need to go in the Device Manager and re-assign your com ports.
Regards
Ray Farmer
Regards
Ray Farmer
(3,346 Views)
I use a product called "USB Serial Converter" (no real manufacturer listed) that had a USB to 9-pin cable and software drivers.  Using this, I can do Rs-232 com over the USB port and the "com port number" always stays the same.  I believe the product was about $20.  Tyhe USB port still functions as a USB port at any time it is needed for that.
(3,330 Views)
