LabWindows/CVI
Help: To compare values in CVI?
Hi
Please help my question:
compare if a value is >, =>, <, or <= in CVI????.  Smiley Indifferent
for example:
V1 = 10
V2 = 5
if V2 => 10 Show MessagePopup ("MSG", "Aouchh if <  ");
Or
V1 = 19
If V1 <=20  Show MessagePopup ("MSG", " Oks if  <");
Smiley Sad One example please!!!!!.
(4,055 Views)
If I understood you, it is simple.
if ( v2 >= 10 ) {
if ( V1 <=20 ) {
See ya
(4,050 Views)
Smiley SurprisedThis type code failure, show error to compare values.
on this msg add my example for you help
ThanksSmiley Wink
(4,044 Views)
Are you trying to compare a String to a double?
I suggest you to use a numeric data type to input the value that you want. There is an option to you choose the right data type. Or you can use a pointer to char and then convert the String to a double using atof command before to compare.
(4,039 Views)
Smiley Happy Ok thanks, with your help my problem was resolved using this code:
using Variable double V1;
__________________________________________
void COMPARE (void)
 GetCtrlVal (PANEL, PANEL_STRING, V2);
 V1= atof(V2);
  if (V1>=2.7)MessagePopup ("MSG", "Result is good, is = or >");
 return;
___________________________________________
Mensaje editado por avalosro
(4,036 Views)
