LabWindows/CVI
Help-byte swap using CVI
hi can anyone help,
i have alot of data (declar:double), how do i bytes-swap all my data using a function on CVI.
Is there any information or example to share?
thanks
chris
(5,402 Views)
Hi Chris,
You can use "endianess" functions...(see attached)
(5,391 Views)
(so I guess that you will need to use "ToOtherEndian64" function)
(5,387 Views)
Thanks for the information,
just to check with you, Do you know CVI is using big or little endian?
(5,372 Views)
hehe im blur, why do you said so( ToOtherEndian64)?, meaing base and above requirement i can only use this( ToOtherEndian64) and not ToBigEndian64 ??? can expain reason?
(5,368 Views)
I think that CVI is using little endian.
For "ToOtherEndian64" function, I was just underlining the fact that "double = 64 bits". But depending on your need, you will maybe have the possibility to use "ToBigEndian64" function. 🙂
(5,354 Views)
About CVI endianess, somebody asked the same question and it seems that my answer was not correct (on my computer it is using little endian, that's why I thought it was the same in every system). The good answer is here :
http://forums.ni.com/t5/LabWindows-CVI/Help-Any-one-can-advice-CVI-software-is-using-Big-or-little/t...
(5,352 Views)
