LabWindows/CVI
Hide the cmd shell
When i use the launch executable hoe can hide the display of command shell winodow...?
For example, if run the following file, command shell appears before it executes.
LaunchExecutable("cmd /C simple_dbg.exe");
(4,116 Views)
Try LaunchExecutableEx and set second parameter, Window State, to  'LE_HIDE'
(4,099 Views)
it helps thanx
(4,096 Views)
