LabWindows/CVI
High resolution screen issue
I'm working with CVI 2013 and got a request from a customer about an issue on his new laptop with a high resolution screen.
Th panel which is causing the issue is set to "Scale contents on resize" and "Resolution adjustments" = 100%.
On my PC with a resolution of 1920x1080 I get what you can see on the attached picture 1.
What he gets on his screen of 3200 x 1800 is what you can see in picture 2.
How can I solve this issue?
(3,879 Views)
Hi Bertrand ENAC,
Thank you for this detailed explanation.
Did you try to put the resolution adjustement to 100% ?
To do that, please follow these steps. To access to this property, you first have to double click on the UIR file and select "Edit >> Panel ..."
Samir
Ingénieur d'applications
National Instruments - France
(3,819 Views)
Edit :
Sorry for my mistake, I've forgotten to ask you to uncheck "Scale Contents on Resize".
Another test that you can do is to create your UIR on a low resolution before using it on a bigger.
I will also do tests on my side.
Samir
(3,809 Views)
