LabWindows/CVI
High speed close loop implementation in CVI5.5 using PCI6014
Hello, I need help to implement a high speed PID close loop (>3-400Hz)control. I use a PCI 6014 device! The loop is single input (one AI), single output (one AO).It is possible to work? Can someone help me? Thank You, Cip
(3,662 Views)
Hello Cip,
Thank you for contacting National Instruments.
This should be possible. Take a look at the following example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=E4CA2D6A5ADF2885E0340003BA230ECF&p_node=201181&p_source=External
This demonstrates how to create a PID Loop in CVI. You will probably need to make some modifications because this was developed in CVI 7.1 with NI-DAQ 7.3.
Let me know if you have any further questions.
Sean C.
(3,656 Views)
Thank You, for your answer.
I will try to modify it because my CVI version is 5.5 and I can't load/open the *.fp and *.uir files.
Cip
(3,653 Views)
Does this also work for CVI 7.1 with PCI6036E?  I mean.. just modify the parameters? is that what you mean?
(3,466 Views)
Hello Jemellie,
The program was written in CVI 7.1 for the NI-DAQmx driver version 7.3, which supports the PCI-6036E. The program should work with your hardware if you make the appropriate modifications to the appropriate parameters.
Best wishes,
Wallace F.
(3,450 Views)
