LabWindows/CVI
How Can I Attach html file to email acount.
I'm trying to send email with html file attached but i'm getting ERROR .
In your sample you attached a BMP file and it's working O.K but when i triied to send another file , NOT bmp file I get ERROR.
Please Tell me how to send HTML File through outlook.
Thank u.
Sruly
(5,326 Views)
Hi Sruly,
I assume that you are talking about the outlookrep2000 example.  Are you using Outlook 2000? Can you simply include an html file from outlook and send it from Outlook?  What error are you getting?  Is there an error code associated with it? Some more specific information will help in finding a solution!
Thanks!
NickB
(5,294 Views)
My problem was that i sent *.html file instad *.htm file, that's why the attachment file didn't send corectly.
now, I have a new problem, I'm trying to send mail and befor it send i'm getting outlook security message , How can I disable it?
Thank u
sruly
(5,244 Views)
Sruly,
This sounds more like an issue with Microsoft Outlook.  Microsoft might be a better place to look for a solution to that issue.
NickB
(5,217 Views)
Someone in the Forum ask that question and u answered him but in spanish, I dont understand Spanish,
Please try to help me solve this problem.
In Visual Basic u can Disable this message, that's not an issue to Microsoft Because in other software u can do it.
Thank u for your quick answer
Sruly
(5,183 Views)
Sruly,
I think that I have found the discussion forum that you were referring to in English here
Also, it does not appear that there is a way built in to CVI to accomplish keeping this message from popping up.  There should be a way within Outlook by browsing to a location similar to that described in the aforementioned post to allow exterior activeX commands to control outlook.
NickB
(5,145 Views)
Thank's for your help.
I solved this problem in the registry.
(5,134 Views)
