LabWindows/CVI
How Do I Calibrate the Voltage Output Range for SCXI-1124 channel using LabWindows/CVI version 4.0.1
I also have NI-DAQ Configuration Utility version 5.1 but that does not seem to have it.
(3,315 Views)
Unfortunately, the NI-DAQ driver command SCXI_Calibrate does not support the SCXI-1124 module. You should follow the steps listed in the SCXI-1124 User Manual in order to perform a calibration. Chapter 5 in the User Manual covers the calibration procedure.
The User Manual can be found by going to www.ni.com/manuals.
Justin Britten
(3,315 Views)
Where can I find instructions for writing to the DAC?
(3,315 Views)
You may use the SCXI_Cal_Constants() function in the NI-DAQ driver. For detailed information on this function, please reference the NI-DAQ Function Reference Manual. This help file may be installed on your computer under Start >> Program Files >> National Instruments >> NI-DAQ or found online at www.ni.com.
Justin Britten
(3,315 Views)
