LabWindows/CVI
How I can take data from serial port with LabWindows( the data are sending to serial port by PIC of Microchip)
How I can take data from serial port with LabWindows( the data are sending to serial port by PIC of Microchip). I need to see the data and to try them.
Mensaje editado por colo10
(4,366 Views)
You might want to look up Opencomconfig() and then choose ComRd(), comRdByte(), or ComrdTerm() for which method suits you best.  Aslo look up InstallcomCallback().
If you need more help, then we need to know what you are needing in better detail.
(4,351 Views)
Repeted post 4  times.
You can use the following page as starpoint:
http://www.ni.com/support/cvi/serlprog.htm
And use the examples in find examples
Benjamin C
Principal Systems Engineer // CLA // CLED
(4,332 Views)
