LabWindows/CVI
How are the tab colors defined in the CVI 6.0 engine?
Using a program from CVI 5.5, I find that the colors for the tabs do not appear correctly when using the CVI 6.0 engine, the colors are lighter than they should be. One of the programs I was using is the tabdemo.prj in the CVI samples directory. The 6.0 engine was installed by TestStand on a system that originally had CVI 5.5. Replacing the 6.0 engine with 5.5 corrects this problem.
(2,840 Views)
Thank you very much for your feedback. We are aware of the issue, and I will posst back whenever I hear any update on this issue.
Mika Fukuchi
Application Engineering
(2,840 Views)
