LabWindows/CVI
How can I append two strings in Labwindows?Say,one is constant string and second one is variable string
Ex:Inppts
string1 is ABC_
string2 is i
outputs should be ABC_1,ABC_2..........
(5,670 Views)
There are several ways to get this done in CVI. One way is to use the Fmt function like in the following way:
#include
#include
#include
int main (int argc, char *argv[])
char constant_string[]="ABC_";
char variable_string[250];
char target_string[255];
int i=0;
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
for (i=0; i<10; i++)
// write to variable_string
Fmt (variable_string, "%s<%d", i);
// append variable_string to constant_string and store result in target_string
Fmt (target_string, "%s<%s%s", constant_string, variable_string);
printf ("%s\n", target_string);
return 0;
Heinrich Illig
National Instruments Germany GmbH
(5,670 Views)
Thanks Heinrich. It works great to me.
(5,670 Views)
Here's a method that will work in any ANSI C compiler.
char outputString[256];
char string1[250];
int i;
strcpy(string1, "ABC_");
for (i=1; i<=10; i++)
sprintf(outputString, "%s%d", string1, i);
/* whatever you want to do with outputString */
(5,670 Views)
