LabWindows/CVI
How can I change column width appended using NIReport?
Hi!
I am programmed print function to print a table using NIReport fp. Everythings works fine, but, a column needs more space. But I can not find any command to control that column width. Is there a way to change column width in NIReport fp?
(oh, I am using LabWindows/CVI v6.0
TIA.
(3,455 Views)
Hello
You might have seen it already, but did the NIReport_TableSetColWidth() function help?
Bilal Durrani
NI
Bilal Durrani
NI
(3,455 Views)
I found that function just few hours ago, and solved without any problem.
Thank you for your help...
But I found that function in nireport.h!
I can not find that info in any other resources such as documents, fps, sample program, help files. I don't know the reason. In 'select function panel' (you can see this panel to double click the nireport.fp file in project window) there is no info related with tables...
Thanks anyway.
(3,457 Views)
There is also  the command Excel_SetProperty with attribut Excel_RangeColumnWidth :
Example :
Excel_SetProperty (ExcelRangeHandle, NULL, Excel_RangeColumnWidth, CAVT_VARIANT, CA_VariantDouble(20.13));
(3,273 Views)
