LabWindows/CVI
How can I change the installed feature set ?
When I did the installation I selected the features I thought I needed.
Sure enough, I forgot to select something.
How can I add it in now?
Do I have to do an uninstall / reinstall or is there a better way?
(3,142 Views)
Hi reeltyme,
You didn't mention what NI software you were using but to change an installed feature, simply go to your Control Panel, select Add and Remove Programs, choose the National Instruments Software item and then click the Change/Remove button. This will bring up a dialog where you can choose the specific version of NI software you want to modify/repair or remove. In your case, choose Modify which will bring up the installer setup dialogs and there you can choose a different install item in the installer feature tree.
Best Regards,
Jonathan N.
(3,139 Views)
Thank you very much! It worked fine.
I don't know why its not easier to find out how to do this via the docs or the on-line Help.
I hate to bother the forum for something simple like this.
BTW the application was LabWindows/CVI version 8.5
(3,124 Views)
