LabWindows/CVI
How can I convert a project from LabWindows/CVI 2010 to a Visual Studio 2011 project?
After performing an update on LabWindows/CVI 2010 (and geting an eval 2013 version) I had working versions of the conversion wizards in VS2010.  Will these wizards stop working when the eval period is up or continue to work with my CVI 2010 version?
Message 11 of 13
(1,385 Views)
Hi dogsled45,
The conversion wizard that is attached to the unlicensed LabWindows/CVI 2013 will stop working at the end of the evaluation period, since you don't have a license for the software.  If you have a license for LabWindows/CVI 2010 that will still work.  Since they are both registered in VS2010, you might have to do a repair on the CVI 2010 install once CVI 2013 eval period is up.
Peter T
Message 12 of 13
(1,371 Views)
When I converted the CVI 2010 project in VS2008, the IDE popped the dialog "Cannot find the VXIpnp Directory",How can i deal with that problem?
Message 13 of 13
(1,349 Views)
