LabWindows/CVI
How can I convert single element array to integer
I have extracted a single element/character from a string using "String Subset Function". I want to convert this to a number eg U8.
The output from "String Subset Function" produces a 1 character string. If I convert it to U8 it produces an array of U8 with one element.
How can I convert it to a non-array variable?
Many thanks
Andy
(3,464 Views)
U8 makes me think that you might have intended to post this question in the LabVIEW forum - while you ended up in the CVI forum 😉
(3,462 Views)
Yes your right, wrong forum.
Please ignore this one. I'll start again in the correct forum.
Many thanks
Andy
(3,459 Views)
