LabWindows/CVI
How can I create a DLL if the file extension is .msi?
I have a problem to create a DLL with a file that I download from your database with extension .msi the error appear like this one "checkerr IVI_INSTRUMENT_FIRMWARE_REVISION" when .c file is trying to compile. when I download an instrument driver with extension .zip it's to easy to create a DLL just with the files .c,.h,.fp but if I try to do the same with the file that I need to install always I get an error in IVI.
(2,838 Views)
I'm not sure what you have, where on the site did you download it? A MSI file is an installer file. If you have Microsoft's installer program installed you should be able to right-click on it and select "Install".
Best Regards,
Chris Matthews
(2,838 Views)
