LabWindows/CVI
How can I create a DLL with LabWindows/CVI with shared memory?
We have several applications, which want to access devices based on CVI drivers. These CVI drivers are encapsulated in DLLs. As multiple applications access the same device DLLs, we don't want to re-initialise these DLLs for each application. So we would need shared memory for the DLLs. Especially, as some CVI drivers need quite a long time for the initialisation.
I know, the question was already posted in a different way, but we desperately need a solution for this problem.
In general, it is just a flag in the .data section of the DLL PE header, so there could be a linker option to allow shared memory for DLLs.
Thanks for any help,
Dieter Pawelczak
(5,200 Views)
I've copied the info from the Windows SDK below, hope this helps...
Or you can do a search for : "Using Shared Memory in a Dynamic-Link Library" selecting topics only for a quicker search
Platform SDK: DLLs, Processes, and Threads
This section shows how the DLL entry-point function can use a file-mapping object to set up memory that can be shared by processes that load the DLL. The shared DLL memory persists only as long as the DLL is loaded.
The example uses file mapping to map a block of named shared memory into the virtual address space of each process that loads the DLL. To do this, the entry-point function must:
Call the CreateFileMapping function to get a handle to a file-mapping object. The first process that loads the DLL creates the file-mapping object. Subsequent processes open a handle to the existing object. For more information, see Creating a File-Mapping Object.
Call the MapViewOfFile function to map a view into the virtual address space. This enables the process to access the shared memory. For more information, see Creating a File View.
// File: DLLSHMEM.C.
// The DLL entry-point function sets up shared memory using
// a named file-mapping object.
#include
#include
#define SHMEMSIZE 4096
static LPVOID lpvMem = NULL; // pointer to shared memory
BOOL DllMain(HINSTANCE hinstDLL, // DLL module handle
DWORD fdwReason, // reason called
LPVOID lpvReserved) // reserved
HANDLE hMapObject = NULL; // handle to file mapping
BOOL fInit, fIgnore;
switch (fdwReason)
// The DLL is loading due to process
// initialization or a call to LoadLibrary.
case DLL_PROCESS_ATTACH:
// Create a named file mapping object.
hMapObject = CreateFileMapping(
INVALID_HANDLE_VALUE, // use paging file
NULL, // no security attributes
PAGE_READWRITE, // read/write access
0, // size: high 32-bits
SHMEMSIZE, // size: low 32-bits
"dllmemfilemap"); // name of map object
if (hMapObject == NULL)
return FALSE;
// The first process to attach initializes memory.
fInit = (GetLastError() != ERROR_ALREADY_EXISTS);
// Get a pointer to the file-mapped shared memory.
lpvMem = MapViewOfFile(
hMapObject, // object to map view of
FILE_MAP_WRITE, // read/write access
0, // high offset: map from
0, // low offset: beginning
0); // default: map entire file
if (lpvMem == NULL)
return FALSE;
// Initialize memory if this is the first process.
if (fInit)
memset(lpvMem, '\0', SHMEMSIZE);
break;
// The attached process creates a new thread.
case DLL_THREAD_ATTACH:
break;
// The thread of the attached process terminates.
case DLL_THREAD_DETACH:
break;
// The DLL is unloading from a process due to
// process termination or a call to FreeLibrary.
case DLL_PROCESS_DETACH:
// Unmap shared memory from the process's address space.
fIgnore = UnmapViewOfFile(lpvMem);
// Close the process's handle to the file-mapping object.
fIgnore = CloseHandle(hMapObject);
break;
default:
break;
return TRUE;
UNREFERENCED_PARAMETER(hinstDLL);
UNREFERENCED_PARAMETER(lpvReserved);
// SetSharedMem sets the contents of shared memory.
VOID SetSharedMem(LPTSTR lpszBuf)
LPTSTR lpszTmp;
// Get the address of the shared memory block.
lpszTmp = (LPTSTR) lpvMem;
// Copy the null-terminated string into shared memory.
while (*lpszBuf)
*lpszTmp++ = *lpszBuf++;
*lpszTmp = '\0';
// GetSharedMem gets the contents of shared memory.
VOID GetSharedMem(LPTSTR lpszBuf, DWORD cchSize)
LPTSTR lpszTmp;
// Copy from shared memory into the caller's buffer.
while (*lpszTmp && --cchSize)
*lpszBuf++ = *lpszTmp++;
*lpszBuf = '\0';
Note that the shared memory can be mapped to a different address in each process. For this reason, each process has its own instance of the lpvMem parameter, which is declared as a global variable so that it is available to all DLL functions. The example assumes that the DLL global data is not shared, so each process that loads the DLL has its own instance of lpvMem.
In this example, the shared memory is released when the last handle to the file-mapping object is closed. To create persistent shared memory, a DLL can create a detached process (see CreateProcess) when the DLL is first loaded. If this detached process uses the DLL and does not terminate, it has a handle to the file-mapping object that prevents the shared memory from being released.
Built on Thursday, October 12, 2000
(5,200 Views)
We are using this approach to share information between 2 apps.
Is this inherently safe to do this, or should the 2 apps obtain a semiphore to prevent stepping on shared memory?
(5,200 Views)
