LabWindows/CVI
How can I create variables on a test stand step using CVI?
I am using "  TS_PropertySetValNumber(  g_seqContextCVI, &sErrorInfo, "Step.Configuration.ReadInputs", TS_PropOption_InsertIfMissing|TS_PropOption_CoerceBadNumbersToZero,  iReadInputsEnabled );" to create the variable and it is shown in the run context.  How do I create this in the SequenceFile under the step?
(3,282 Views)
To create a property as part of a step, you will need to create a custom step type which has the property 'Configuration.ReadInput'.
There are examples of custom step types on the NI website.
Regards
Ray Farmer
Regards
Ray Farmer
(3,269 Views)
Try this link for creating a custom step type.
Regards
Ray Farmer
Regards
Ray Farmer
(3,265 Views)
Thanks, I new that, I should have been clearer.  I was hoping that there was a way of creating a variable without creating a step type.  It would be nice if my DLL could create all variables that it need on its own.  Then, if there are anything changes, only the DLL has to be updated.  Therefore, I only have to manage one item as opposed to two (DLL and Step Type).  Less confilicts.  Easier to maintain compatibility.
(3,260 Views)
