LabWindows/CVI
How can I debug the stack size
I have a big problem with a tool I programmed.
The program (exe) shut down after 2/3hours without any error-message.
Propably there is an stack overflow and I want to control the step size in the program.
Is it possible to ask for the actual needed stack size?
Because of the bigness and the routines of the program, it is impossible to debug it.
Thanks a lot
Andreas
(3,393 Views)
Just out of curiosity... are you using recursive functions?
If you are and they require large data sets, you really ought to be allocating the needed storage space on the heap using malloc() or calloc() instead of using the stack. The heap has a much larger space limit than the stack.
Of course, if you do this, you will need to be careful about freeing those allocated blocks when you are done with them to prevent memory leaks.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,375 Views)
