LabWindows/CVI
How can I display the date and time of the a file in a textbox?
Hello PRK123,
first of all, you are reviving an old thread with an unrelated question. In this case it is always better to start a new discussion instead.
Having said this, I can give you a conceptual framework for you to elaborate on. To accomplish your task you need a periodic function that checks execution time: this can be obtained with a timer firing a slow rate (say once per minute). in the timer callback you have to elaborate the time figure and decide if you need to shutdown the application: in this case you prompt a message and issue a call to QuitUserInterface. Before closing the application you may need to stop ongoing processes (e.g. acquisition tasks) and dispose of allocated resources (connected external devices, open files and so on).
Message 11 of 11
(250 Views)
