09-07-2005 05:03 AM
09-13-2005 09:19 AM
You're right, it was changed somewhere with microsoft's updates, I've defenately used it on Win2K before and the specific field is not available on my current registy fields under win2k.
There should be an entry called shell under
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
there's a new field theer however
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\AutorunsDisabled]
and under that "Shell"="Explorer.exe"
To disable the task manager add this line to the registry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\taskmgr.exe]
"Debugger"=""
