LabWindows/CVI
How can I fine adjust the size of a Command Button?
Is there any way to fine adjust the size of a Command Button graphically?
In VB for example, you can bring the properties up and adjust the dimensions of the button.
Is there anything like it in CVI?
Rafi
(3,157 Views)
In the UIR editor, highlight the control you want to size, then goto menu Arrange >> Control Coordinates. You can set the location (top and left) as well as the size (height and width). To set multiple controls to the same size, highlight multiple controls in the editor, then goto Arrange >> Control Coordinates, enter the desired height and width, then click on the All buttons under height and width.
(3,156 Views)
