LabWindows/CVI
How can I get an array size in CVI
It should be very easy, but I still can not find correct function I could use? Below is my code and I want to get the array size of variable "firstFile"
Jacky
int CVICALLBACK PanelCB (int panel, int event, void *callbackData,
  int eventData1, int eventData2)
 char** files;
 char*  firstFile;
 switch (event)
  //This event occurs when files are dragged and dropped on the panel
  case EVENT_FILESDROPPED:
   files = (char**)eventData1;
 //  firstFile = files[0];
   break;
 return 0;
(3,973 Views)
Hi Jacky.
How about strlen(firstFile)?
I assume that you have called EnableDragAndDrop() for a top-level panel, and you want to know how many files were dropped. You could try something like this to iterate through the file list:
int CVICALLBACK PanelCB (int panel, int event, void *callbackData, int eventData1, int eventData2)
char** files = NULL, **ppc = NULL;
char* firstFile;
int length;
switch (event)
if (files)
// Get first file pathname
// Get length of pathname
length = strlen (firstFile);
ppc = files;
while (*ppc)
printf ("Selected File : %s\n", *ppc);
free (*ppc);
*ppc = NULL;
ppc++;
free (files);
files = NULL;
break;
return 0;
Note: adapted from the CVI Help for the function MultiFileSelectPopup().
Hope this helps.
Colin.
(3,953 Views)
