LabWindows/CVI
How can I get the Lable value of Recessed Menu Ring Ctrl?
There are two characters in the control setting of "Recessed Menu Ring" Ctrl which are "Lable" and "Vaule"(Lable/Vaule Pairs). Use "GetCtrlAttribute" function can only get the value of "Value". But I want to get the vaule of "Lable". I find nothing relation to "Lable" after I search all the control attribute in the "GetCtrlAttribute" function. How should I do?
(3,092 Views)
GetCtrlIndex retrieves the index of the label/value pair that is actually selected on the control. You can pass this value to GetLabelFromIndex and retrieve the label associated with that particular label/value pair.
You can also retrieve the label of an item not actually selected in the control, knowing the value associated with it: use GetIndexFromValue function to retrieve the index associated with the desired value and pass it to the functions describer previously.
(3,086 Views)
Thank you very much. It does work now.
(3,083 Views)
