LabWindows/CVI
How can I launch the default e-mail client?
There's more info here on mailto, but I couldn't find a way through mailto to actually send the email.
If you're using Outlook, look at the sample project that ships with CVI:
...\CVI\samples\activex\outlook\outlookrep2000.prj.
See the callback SendEmail.
Message 11 of 14
(1,394 Views)
Foxfire,
If you would like to generate the message and automatically send it through CVI I would suggest looking at the InetSendMail function. Will will allow you to send an email directly through an SMTP server.
int InetSendMail (const char *Server, const char *From, const char *To, const char *Subject, const char *Message_Text, const char *Attachments);
Alternatively, if automating the default email client is necessary, another option might be using ActiveX to programmatically control the email client
Scott Y
NI
Message 12 of 14
(1,596 Views)
I tried the same call but nothing happens.
ShellExecute( NULL, NULL, "mailtoerson@company.com", NULL, NULL, 0);
What I want is only to open a new mail with the adress and subject field filled in.
The body must be written by the user.
Thanx in advance
Message 13 of 14
(937 Views)
Hi PerBorgvad,
the correct syntax for mailto requires the command is separated from the address with a ":"; informations on mailto command are available on the interenet, for example here: you can add the subject by embedding it in the command:
mailto:address@server?subject=Subject
I never really tried it within CVI environment but it should work.
Message 14 of 14
(930 Views)
