LabWindows/CVI
How can I make a componment for CVI??
As subject!
(3,211 Views)
Could you please explain your quesion more in details?
Mika
(3,211 Views)
As I knew CVI have many componments just like LED,Binary Switch ,Ring ,String ...
If we want some componments and CVI not have.
How can I make new componments for CVI??
(3,211 Views)
CVI is a 'closed' system and you cannot add components that integrate as well as the built-in components.
The best you can do is to modify the behaviour of an existing component (in the most general case, a canvas control) using your own initialisation and event handling functions and wrap the whole lot up in a function panel.
NI provide several examples of this approach, you will find them in the toolslib\custctrl sub-folder.
HTH, HAND,
Martin.
Martin
Certified CVI Developer
(3,211 Views)
