LabWindows/CVI
How can I make my own Ethernet frames
Hello
I'm trying to compile a cvi project with the winpcap library, but I can't.  Instead of using winpcap files, I think it would better if I can make my own ethernet frames, using my own data and protocol (neither TCP/IP, nor FTP, nor whatever).  Can I do this with CVI?
Carlos Arcediano del Amo
(3,309 Views)
Hello Carlos,
I hope this post may help you.
http://forums.ni.com/ni/board/message?board.id=170&message.id=45269&requireLogin=False
Regards
DiegoM.
(3,265 Views)
Hello, Diego
I have finally solved my problem by compiling my CVI program with the winpcap DLL.
The solution is here:
http://forums.ni.com/ni/board/message?board.id=180&message.id=18861
(3,236 Views)
