LabWindows/CVI
How can I make small distribution kit in CVI 7.1
I need to build a small distribution kit, My app distribution kit size is 6 MB - How can I make it smaller?
Message 1 of 10
(4,371 Views)
Erez,
Are you including any files with your distribution kit such as .bmp files?  Bitmaps tend to be rather bulky and you can make them take up much less space by saving them as a .pcx file (assuming that you are using them in your controls since CVI supports .pcx).
Message 2 of 10
(4,358 Views)
I had two bmp files with picture controls, I removed them from the project but still have 6 MB setup.
Message 3 of 10
(4,354 Views)
Erez,
What other types of files do you have?  Is it a couple big files, or lots of smaller files?
Message 4 of 10
(4,351 Views)
I have 1 uir with 3 panels and 170 lines of code
Its a small application
Message 5 of 10
(4,326 Views)
ok, I know this is not a direct answer, but maybe worth to consider anyways.
what about having customers just install cvirte (+ni-daq in case your programs does data acq) once and subsequently
send them zip files, only containing the executables+uir for your app (these are rarely > 1MB in most cases).
at least, this is what I do after some hassle with dist. kits.
it may not be elegant, but it works.
Once the game is over, the king and the pawn go back into the same box.
Message 6 of 10
(4,318 Views)
Erez,
When creating a distribution kit we should see the following files:
DistFile.cab
instmsi.exe
instmsiw.exe
setup.exe
setup.ini
TestProj.msi
Now, as long as the target machine isn't a windows 9x or NT 4.0 (not sure about win2000) you don't need to have the instmsi.exe or instmsiw.exe in your kit.  To experiment with this I created a distribution kit and deleted before install and didn't have a problem when i used TestProj.msi or setup.exe (I'm running windows XP).
instmis.exe - only used for windows 9x
instmsiw.exe - only used for windows NT
knowing this, you could make three separate kits, one for each platform set, this would definately save you some space.  You could also zip the entire project up and save yourself some space.  Using this method, you can get your kit to under half the size of the original 6 meg (probably around 2.7 megs).
Message 7 of 10
(4,312 Views)
Bouth files size is about 3 MB
That help a lot
Thanks very much
Message 8 of 10
(4,310 Views)
Hi.
I found some useful information on this topic here.
Colin.
Message 9 of 10
(4,278 Views)
Under target settings uncheck Enable loadexternalmodule. I am guessing you are not calling external dlls by using LoadExternalModule.
By default it is enabled but most people don't need it. This will reduce your distribution size.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 10 of 10
(4,256 Views)
