LabWindows/CVI
How can I modify CVI Toolbox to support REG_EXPAND_SZ?
In Windows XP, the registry contains key type REG_EXPAND_SZ, which the toolbox routines do not handle. How can I modify toolbox.c so that this key type is supported?
(3,102 Views)
Hello
The code for the toolbox is provided to you, you can find the C file under ..\CVI\toolslib\toolbox. You will notice that all the functions are just wrappers around the windows api, you can view in the implementation of the registry write methods available in the toolbox, and you can safely add another function to support expandable strings.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,102 Views)
