LabWindows/CVI
How can I open an existing Word file?
I am new in using Labwindows and i want to open an existing Word file.
Is it possible without any Word Libraries?
After pushing a Button in the User-Interface, i want to open a Word file.
Sorry for my bad English.
Florian H.
(3,528 Views)
you need this function.
OpenDocumentInDefaultViewer ("your filename.doc", VAL_NO_ZOOM);
Include toolbox.fp in your project.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,512 Views)
Unfortunately the solution proposed by test_man is not working unless you have Word installed on your machine: OpenDocumentInDefaultViewer relies on the viewer (or editor) to be installed on the machine and registered for that particular file type (the same as double clicking a file in Windows Explorer).
An alternative to full Word application, but not usable for editing, is to install the word viewer, which permits you to open and print a document.
(3,505 Views)
thank you for your answers.
" OpenDocumentInDefaultViewer ("your filename.doc", VAL_NO_ZOOM); "-Function works!
Best regards
Florian H.
(3,486 Views)
