LabWindows/CVI
How can I organize multiplethreading access to the database via SQL CVI Toolkit?
I have to organize multiplethreading access to the database Access (Microsoft Access Driver in ODBC).
I have tryed to use function
DBInit (DB_INIT_MULTITHREADED) before function DBConnect, but this function doesn't work (returns error code).
I have 3.525 version of ODBC.
I use LAB Windows/CVI 7.1.
Note that singlethreading access work successfully.
How can I organize multi-threading access to the database?
Maria.
(3,284 Views)
Try configuring you Access database as a System DSN.
What is your error code?
If it still does not work, attach you database along with code and I will try it.
robskii
(3,255 Views)
Thank you for your reply.
I'll check what is an error code and I'll back with reply tomorrow.
(3,242 Views)
I would make sure that the Microsoft Jet drivers are also atleast on version 3.   Prior to that, I don't think the Jet drivers were multithreaded.  This might be your problem.  But your system would have to be way out of date...
Orlan
(3,234 Views)
Thank you to all ! After I register it as DSN server it works successfully.
(3,181 Views)
