LabWindows/CVI
How can I perform Data Acquisation with board PCI-DAS6025
DEAR I am using Measurement Computing's board PCI-DAS6025 for data acquistion in LabWindows 5.0. How should I perform data acquistion? I configured this board using 'InstaCall' provided by Measurement Computing. Whenever I use 'EasyI/O' or 'Data acquistion' Library provided by LabWindows, I always get same error Like "Device is not of National Instruments"
Raheel
(3,380 Views)
Accepted by topic author Rahil
You cannot use National Instruments' data acquisition APIs (NI-DAQ and NI-DAQmx). You will have to install the Measurement Computing Universal Library software and use that API instead.
The Universal Library software is distributed on the CD that comes with the card, or you can download it from Measurement Computing's website www.mccdaq.com.
Martin
Certified CVI Developer
(3,376 Views)
Thanks Dear. Measurement Computing has provided Universal Library for this purpose and procedure to use within VC++, C++, VB, LabView. I do not know how to use Universal Library with LabWindows.
(3,369 Views)
