LabWindows/CVI
How can I programmatically enter the value inf or NaN into a variable
My program saves and reads float data arrays to/from files in text format.
However, when a value is +inf, -inf or NaN, this ends up in the text file. So far no problem. The problem starts when I try to READ the text file. I want to restore the array to its previous state, including inf and NaN values.
When encountered during read, how do I assign these values to a variable programmatically?
Or, what are the #define values of NaN etc, if any?
Erwin Timmerman
(3,450 Views)
Hi Erwin,
Please have a look at this discussion: Not a Number, as it details also about the same problems.
I hope this answers your question.
ErikvH
Applications Engineering
(3,450 Views)
Also, if you're using CVI 7.0, you can use the PositiveInfinity, NegativeInfinity, and NotANumber functions from the Programmer's Toolbox Library.
Luis
NI
(3,450 Views)
Which section of the Progs Toolbox are these functions in? I couldn't find them.
Paul
(3,450 Views)
