LabWindows/CVI
How can I read a bitmap out of a PDF
does anyone of you know how I can read out a bitmap out of a pdf file. Today I saw a software which can do this but I do not know how.
I want to compare two bitmaps with each other and one of the bitmaps is inside a pdf.
Is there any way how I can read this bitmap out ?
thanks
Oliver
(3,338 Views)
hello oliver,
there is no native library, which supports the operation you want to perform.
there exist some libraries for parsing PDF-files for example fpr perl:
http://search.cpan.org/~antro/PDF-111/PDF/Parse.pm
i found also a general article about parsing PDFs:
http://www.pongacomputing.net/articles/parsing-pdf-documents
so if you want to extract information out of PDF-files you will need some library, which provides you this functionality.
kind regards,
Robert H
NI germany
(3,315 Views)
Hi Robert,
thanks a lot for your help. I will check this.
Oliver
(3,310 Views)
