LabWindows/CVI
How can I read the PXI-Chassis-Type (LabWindows/CVI)?
How can I read the PXI-Chassis-Type?
I use in different test-stands different PXI/SCXI-Chassis for the same project. For example: Some test-stands have a PXI/SCXI-1052-Chassis, others have a PXI-1033 and a SCXI-1000 Chassis. Because I have to use different DIO-Ports (Ports 0.0, 0.1... are reserved for internal communication between the 1033 and the 1000-Chassis) I want to read the used devices.
I think one way is to use the registry-entries, but I'm not sure...
My current LabWindows/CVI- version is 8.5.1.
Thanks for your ideas!
Jagger_HKG
(3,069 Views)
Hello Jagger_HKG,
you could use the NI System Configuration API.
Kind regards,
Robert H
NI Germany
(3,061 Views)
